TwinTurbo.NET: Nissan 300ZX forum - Re: sounds like a vacuum leak. As for timing it is set at >>
sdvdoc
on October 14, 2014 at 5:56 AM
posted by ZUL8TR
on October 14, 2014 at 03:05 AM
It was lined up when I completed the timing belt but I will check it again. I'm not sure where a vacuum leak could be. I've researched that extensively over the past 3 weeks but I will look again. Thanks.
Master Z mechanics please help.
sdvdoc
21:46:25 10/13/14
Your timing is at 15 degrees at 2500 rpm? (n/m)
BarryGZX
21:56:09 10/13/14
Re: Your timing is at 15 degrees at 2500 rpm?
sdvdoc
06:00:04 10/14/14
15 btdc at 2500 rpm is way retarded
BarryGZX
20:01:22 10/14/14
Re: 15 btdc at 2500 rpm is way retarded
sdvdoc
20:29:32 10/14/14
ZUL8TR
03:05:03 10/14/14
Re: sounds like a vacuum leak. As for timing it is set at >> -
sdvdoc
05:56:20 10/14/14
This might help with the vacuum testing >>>>>>>>>>>>>
ZUL8TR
04:47:05 10/15/14
Re: Master Z mechanics please help.
backinblack626
10:30:30 10/14/14
Re: Re: Master Z mechanics please help.
sdvdoc
19:04:48 10/14/14
